It is currently Fri Aug 15, 2025 6:08 pm
PostPosted: Fri Oct 17, 2014 2:21 am
First name: Brad
City: St. Louis
I'm working slowly but surely on my first build, and when I cut, bent, and glued up the sides to the blocks I came up short. The gap is right where the dovetail will be cut and joined, so I'm wondering if this a non-issue once the dovetail cuts are made, or will part of this gap stiill be visible once the neck is mounted? Certainly not the best pics, but hopefully they're enough to show what I have going on.
Brad
PostPosted: Fri Oct 17, 2014 2:46 am
Last Name: Kincheloe
Looks fine to me. The back binding should cover any that would be visible below the heel cap.
PostPosted: Fri Oct 17, 2014 5:22 am
Fit a small scrap at the bottom so that when you rout the binding, you don't dig into the back.
These users thanked the author Haans for the post: Leftyprs (Sat Oct 25, 2014 9:45 pm)
PostPosted: Fri Oct 17, 2014 7:46 am
Looks fine to me. You will be cutting most of that out anyhow.
PostPosted: Fri Oct 17, 2014 10:53 am
Be sure to take Haans's advice on fitting in a scrap piece and it'll be fine.
PostPosted: Sat Oct 18, 2014 8:52 am
First name: Patrick
Last Name: Hanna
State: Missouri
Yes, I think Haans gave very good advice. The back binding will cover the very bottom of your patch. Make sure the heel or a heel cap comes down to the binding. I don't anticipate any structural problems whatsoever. Any potential visual problems will be easy to cover with the binding and heel cap. Press on!
PostPosted: Sat Oct 18, 2014 10:24 am
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
You made it this far, so I'm sure you'll find a way to make it fine! Don't over think it or be afraid to come up with a solution that changes your plans a tad. It usually happens.
PostPosted: Sat Oct 18, 2014 12:05 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I just re-read this and I want to clarify my earlier post:
I did NOT mean "yes it will give you problems". I meant "yes, that's good advice".
I hope I didn't confuse you with that earlier comment. You'll be fine! Please let us see it when you've finished.
PostPosted: Mon Oct 20, 2014 7:09 am
First name: Buzz
Last Name: Roberts
City: Crystal Beach
State: ON
Zip/Postal Code: L0S 1B0
I did exactly the same thing on my first guitar. Cut it twice and it's still too short. If you do what Haans suggested you'll be just fine as it will all get cut out or covered. Just remember, it's not a mistake unless you can't fix it.
The long way around is often the fastest way there.
These users thanked the author BuzzRoberts for the post (total 2): Leftyprs (Sat Oct 25, 2014 9:44 pm) • cphanna (Mon Oct 20, 2014 9:29 pm)
Users browsing this forum: Bing [Bot] and 15 guests
